edbtzy
Active member
I was about to take that approach. Do I need to do anything to my phone before I redo most of the steps ( restore back to stock) or should I just do the steps all over again
I'm not sure if I flashed a RVU
Menu > Settings > About phone > Software Information - Build number
So, I've rooted my EVO... got wireless tether working (sweet).. And, actually, IMO - I LOVE the ability to now reset the Phone, using an app... instead of pulling the friggin battery.
But, I haven't found the answer to this. When Sprint pushes the next update (perhaps froyo?) will I revert back to non-root SPRINT? Do I have to re-root every time Sprint updates. Is there an effective way to prevent sprint from updating (I read that you could rename a file (don't remember file name) eg. sticking .bck on it.... but I've read that's not efficient and actually causes the phone to keep trying to apply the update (or something like that).
So my question.
How do I stay rooted...? Can I prevent Sprint Updates? Is it a forever battle? I root, sprint updates, I root, etc.????
I used to have a Palm Pre... with the pre I'd apply patches, Sprint would update, and I'd re-apply the patches...
Personally, I'd like it if I could block Sprint! and control my own phones destiny. Any informative response would be greatly appreciated.
Yeah, definitely some odd stuff going on...No matter if I restart or kill the data connection, as soon as its back on the sync icon appears and data starts running. Phone is running a little hot now and it is sucking the juice.
Any ideas? Or did I skunk myself?
Thanks
The reason they keep appearing for you is you need to do part 2 of toasts root and unlock NAND.great work guys! I'm sorry, I still didn't see how to make then stay "gone". You all tempted me too much and I dove in, did the simple SD card root, Titanium backup, (couldn't figure out what nand was or how to use it) and they apps reappear.
Sorry to bother, just trying to ride your coattails...
Thanks!
Want to provide some clarification for the two guys above ...
What you have done so far is only root your phone. This allows you to run certain apps that need root access to the phone. What you need to remove the bloatware is to unlock NAND after you've rooted (part 2 of toast). What unlocking NAND does is give you r/w permissions to the system directory. Until you unlock NAND you only have read access which is why it looks like you delete the app but they pop right back up.
Hope this helps
This is the part where I'm lost. What part unlocks NAND? I thought I followed the instructions to the letter, even though I "coding illiterate"
