mike_k#AC
workaround
I think I finally found a workaround. Go to the mail app, open the trash folder. I had ~3000 files. Don't use the multiple delete as this will increase the apps size and lockup the phone (mine ran out of space). If you delete these individually it will start to decrease the size used.
If you use the multiple delete it increases the mail app data size, not sure why. If you go back in and delete a few individually it will bring it back down.
Recommend only deleting them individually.
Hope this helps.
HTC where is the fix, I've seen postings for March of last year on this problem.
Mike
Hope this helps.
Mike
