Question Huawei honor 10 lite fingerprint lock not working
Saad
16
I'm unable to apply fingerprint lockscreen or any other pin pattern or password on my honor 10 lite, fingerprint is not faulty as I checked in the sensor test list it passed the fingerprint test, this problem started when I hard reset the device, before that fingerprint was working, when I try to apply a pattern or pin after the 2 steps, it returns back to the same screen its a loop
Saad
16
Can you guys please check this video I found on youtube, and tell if this can solve my problem? Because the none and swipe option is not grayed out but totally gone from my device but its the same thing afterall
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,620
4,763
113
Unfortunately, you've done pretty much everything that we'd suggest to try to fix this. For something as integral to the system as the screen lock to fail, it would most likely be a problem with the hardware or firmware, and there wouldn't be any easy fix.
Reactions: Saad
