MrSmith317
Mr Fix-It
Yeah well if/when you see a mod, let me know lol. They know we play nice here so they don't come around much any more. We're the upper middle class white neighborhood of the Rezound.
Give it 10 minutes to get there
Sent from my ADR6425LVW using Tapatalk 2
an update is due tonight or Monday night...more than likely tonight
A new leaked RUU?an update is due tonight or Monday night...more than likely tonight
has anyone figured out why some folks are having issues getting the image to read properly in hboot? I spent a good amount of time trying to install the leak over the weekend with no success. I downloaded the leak from multiple sources, and in each case, verified the MD5 checked out. However, upon copying the zip file to the SD card and verifying the name is correct and there wasn't a 2nd .zip extention in the name, i still have issues in hboot. I get an error when booting into hboot giving the "no image or wrong image" 4x or so before it quickly takes me to the hboot menu. refreshing the bootloader does not correct the issue - any help would be great. would love to get ICS working! thanks in advance! I am completely stocked, and locked fwiw.
Yup, i've verified it's location - sorry, forgot to mention in my original post. It's definitely on the external SD card. Your guide is definitely helpful...i had it up on the screen the entire time i was working on it, just to make sure i didn't miss any steps.
If it is truly on your external SD card (if using Astro, it will be /ext/sdcard2), then, you will need to check to make sure the file is named properly, no extra .zip, and/or quotes.
