Is my phone waterproof or water resistant?
A
AC Question
My phone and I go near water everyday and there are some CLOSE calls. I need to know. Its a Kyocera hydro life android 4.3
ab304945
1,593
54
Re: Is my phone waterproof or water resistant
IP57 certified - dust and water resistant
- Water resistant up to 1 meter and 30 minutes
italygrl1
72
Phones are water resistant since they are electronic devices. Submerging in water would fry the inner working so try to be careful.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
The last warterproof phone (meaning guaranteed if it got damaged by water) was the nextel i700.
Put your phone into a ziplock baggie and zip it shut. Insert that, zip end first, into another baggie. Zip that one shut. (Test the bags without a phone first - some brands leak.) Now you can toss any phone into the water. (Hose the baggie off first, then let it dry, before opening anything.)
If you fasten (no holes, please) a large key float to the baggies, even if you drop your phone over the side of a boat in a deep lake, all you have to do is reach out with a net and get it back - it won't sink. (You should see the jaws drop when you nonchalantly ask "Does anyone have a net, I dropped my phone in the water", then bring it back and finish the call you were on. You'll be able to sell the bags for $5 a pair.)
TexasIndia
