[KERNEL][ICS] Matr1x Kernels
Skunkape60
4,460
344
Sorry for the noob question- but in the original post- CFS vs. BFS versions to download... what's the difference?
Planning to try this with Codename Android.
Thanks in advance.
Cfs is more for multi tasking and stability.
Bfs more for playing games but may be little less stable.
I've used both matr1x versions and my phone ran very well on both. Never had any stability issues with either.
__________________
Just flash it !!!
Reactions: whippingboy
whippingboy
561
27
Re: [KERNEL][ACS]*Matr1x* [ALL VERSIONS including ICS]
Much appreciated. Thx for the explanation. Wierd how different kernels allow different rooted app permissions... I noticed with this new ROM I can only get the voodoo sound and not voodoo color- so glad Matrix re-enables the color settings- can't live without them!
rem_kujawa
1,673
32
It would be awesome if back light notification would be set to off by default.
Skunkape60
4,460
344
That wouldn't make any since. Most people prefer the standard buttons to the on screen buttons.
____________________
Just Flash It !!!
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Re: [KERNEL][GB][ICS] *Matr1x*
v17.0 is out....
Hit the OP and click on the Source/Link at the top of the page under the ICS versions for the download link.
kevincwelch
582
47
lol... Most people like that feature as well. Why disable by default, the features most of us use?
-1 for me.
I prefer the BLN off. I also have the BLD set to 10,000. IMHO, no sense in having any lights burning battery when I don't really take advantages of them...
toothmkr57
ok, I have researched as much as I think i can... everytime i go to install this kernal I get e:signature verification failed... I am rooted and running codename ics 1.3.3 rom for my nexus s 4g.... I have nexusS4Gtwrp installed as the recovery manager... but other than that there's nothing that i can figure..
any help is appreciated
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Do you have md5 check enabled in TWRP? Just a thought, otherwise re download the kernel and try again.
kevincwelch
582
47
Anyone try the 18.0 version? I'm using it with CM9 Euroskank, and even though it is smooth, my battery life has tanked. I'm going to flash the CM9 optimized version to see if that helps.
demonmz
Active member
Mar 20, 2012
32
Hey is this kernel only for galaxy nexus and nexus s? Does it work for galaxy s? And what's the difference between CFS and BFS?
Paul627g
Moderator
Nov 25, 2010
15,963
2,752
Yes its only for the Nexus line.
You can Google the exact description of CFS and BFS but in short..
CFS is a more stable, less likely to cause trouble build of kernel.
BFS is more of a heavy multitasker/gaming version of the kernel and can be buggy at times..
Reactions: demonmz
xak47d
