Lock Screen Help
lacit1707
9
So, i noticed that some apps automatically have a locked bar on the "Lock Screen"....my flashlight app put one on automatically and i was able to remove it in the actual app. I have 1Weather app/widget downloaded and it put a weather bar on my lock screen and i cant seem to be able to remove it.
Anyone know how i can do this?
Saros
272
1Weather will display on the lock screen unless you uncheck the "Ongoing notification" setting in the app, which is enabled by default. The only consequence in making the change is that it ceases displaying your temperature in the status bar area.
Saros
272
yessss... thank you! i do like the task bar notification too... ill download another weather app that displays that... thanks again.
Glad to help.
I used to prefer only seeing the current temp displayed in the status bar, but grew so fond of 1Weather's widgets that I just made room for them on my home screen instead.
Abhishek397
