I know about the blue tooth disconnect causing muted volumes, this is different.
The output of the Media Player, even at volume level 15 is not that high. Two examples:
1: In a car with an AUX input, my pre I could put the volume at close to max and have it be similar to the radio volume ex, radio is at lvl 20, pre could be lvl 22 or 23 and be similar. With the epic, even at max media volume, I have the have the radio at 35 to even get close to the 20 of the over the air radio volume.
2: when mowing lawn with blue tooth headphones, I have BT maxed and media player maxed and I still can't hear it well, used to have to have pre at 3/4's and I could control volume with BT headphones to get desired level.
Is there a fix for this, are the guys running the GB roms seeing if this is better or worse?
