[MEGATHREAD] What is app 10xxx?
morpheusoptic
Unknown app "10252"
I was recently looking at my data usage in the settings menu and noticed an app I have never seen before. Does anyone know what the one that says "10252" is? I have no app by that specific name and there is no way to go to the app settings by clicking on it from the usage menu.
I looked through all my apps in the app manager and it is not listed in any slide eg. Running, downloaded or All. If anyone knows what this is I would appreciate it.
The only data it uses is background data, which I have subsequently turned off.
Thanks in advance.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,713
4,871
113
Re: Massive battery draining by an app that showed up as Android 10163 ! What is it?
Welcome to Android Central! Since it's an app you uninstalled recently, that listing should disappear after one or two more battery charge cycles.
A
Android Central Question
What are these apps on my android," 10314" and "10475"
These apps are running in the background. Need help to identify.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Re: What are these apps on my android," 10314" and "10475"
Welcome to the forums. Those 10xxx names usually refer to apps that were uninstalled recently. Where are you seeing them, battery, data or memory stats?
I would recommend you to create an account so you can reply on this thread.
A
Porque la aplicación 10199 aparece como restringida y es la número 1 en uso de datos
Esta aplicación me aparece desde el 30 de noviembre como la primera en uso de datos estando desactiva el 28 de febrero asta el 29 de marzo y luego volvió a aparecer no se que función tenga y no me deja desinstalar la aplicación ya que no aparece como existente asta que reviso consumo de datos
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,713
4,871
113
Re: Porque la aplicación 10199 aparece como restringida y es la número 1 en uso de datos
Welcome to Android Central! From Google Translate:
"Why application 10199 appears as restricted and is number 1 in data usage
This application appears to me since November 30 as the first in data use, being deactivated from February 28 to March 29 and then it reappeared I do not know what function it has and it does not let me uninstall the application since it does not appear as existing Until I check data consumption"
Which phone? Apps that have a name in the 10xxx format refer to an app that has been uninstalled. The data usage only represents the data used by the app before it was uninstalled.
Have you uninstalled any apps recently?
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,813
6,384
113
Try to charge your phone to 100% and see if it still in battery stats or data stats
A
How did this app appear on phone? App 10296
An app 10296 showed up on android & is using my data. I didnt do this. It has an android symbol next to the numbers
Mooncatt
Ambassador
Feb 23, 2011
10,788
366
83
Re: How did this app appear on phone? App 10296
Welcome to the forums. Have you uninstalled recently any app? Those 10xxx processes usually refer to removed apps.
Additionally, the data usage being reported is what the app had used during the current monitoring period before you deleted it, and it's not using any additional data. In other words, that entry is nothing more than a place holder and will go away at the start of the next monitoring period.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,813
6,384
113
Yes next battery cycle should see it gone
A
Que son las aplicaciones 10198 10197 y etc
Me aparece que esas aplicaciones utilizan mi wifi y no encuentro de que serán ya que solo me salen los números ya acabo de restaurar mi teléfono de fabrica y siguen saliendo y que utilizan mi wifi
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,713
4,871
113
Re: Que son las aplicaciones 10198 10197 y etc
Welcome to Android Central! From Google Translate: "What are the applications 10198 10197 and etc. It appears to me that these applications use my wifi and I can't find what they will be since I only get the numbers, I have just restored my factory phone and they keep coming out and they use my wifi."
Apps that are shown as "10xxx" in the Data Usage menu simply represent apps that have been deleted. It shows data that the apps used up until they were deleted. They aren't using any more data after they were deleted, and they should disappear from the Data Usage menu when the data cycle resets for the month.
A
10242 is draining my battery and 10237 is using my data!
I had found something unknown when I am Open battery usage then there 10242 is draining my battery and I had found data usage that 10237 is using data.
Laura Knotek
Moderator Captain
Moderator
Jan 8, 2011
11,892
4,293
113
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,713
4,871
113
Re: 10242 is draining my battery and 10237 is using my data!
Welcome to Android Central! App names in the 10xxx format represent apps you recently uninstalled. What you're seeing is the data used by the apps you recently uninstalled. They should disappear after another battery charge cycle or two.
Mooncatt
Ambassador
Feb 23, 2011
10,788
366
83
I'll third B. Diddy, but additionally point out the data usage will not be remove until the next data cycle. These are not usages current happening, but usages that happened while the apps were installed. Now that you uninstalled them, the usage didn't magically go away and these are just place holders so the charts and percentages add up correctly.
Milaco
