sonofevil77
And mine just started doing this 2 days ago. Wtf! It is very strange that we are all having this problem.
Reading one-by-one, isolated, I would surely state you all have bad batteries... and me too.
But it is really weird that we all started reporting that same issue about same time - is it possible that we had a bad SW update to explain such bad behavior? Isn't it too much for a coincidence?
The issue I have is slightly different, though pretty much the same (what inconsistence lol):
Seems that, if I keep my watch on the wrist, it will work as used to, similar autonomy with one charge, and will keep working until battery level is somehow close to zero; BUT if I take it off and e.g. leave it on my desk for some time, it will "turn off" somehow and won't turn on again unless docked. In that case, docking is the single way to turn it on again, button long-press does nothing. Then once on again I see that the battery still has juice. But again, mine does not power off if on the wrist... or not yet.
And this behavior of mine is what triggered my thoughts about bad software instead of bad battery, single reason that made me search around and reach this forum - otherwise I would consider it just a battery in need of replacement.
Hi,
I have a 1st generation Moto 360. It turns off, and it won't power back on unless it is on the charging dock. When it turns off, it just goes to a blank screen. It does this even though it has battery life (e.g., 77%). Also if I manually turn it off, it won't power back on unless on the dock.
The watch and phone (Samsung S7 Edge) were unpaired, and a factory reset was performed. The watch still turns off after a few minutes to an hour, and now I can't re-pair the watch and phone. The phone and watch can't seem to see each other.
If this helps, I am running Andriod Wear 1.4.0.2580363, Play Services 9.4.52, and Andriod OS 6.0.1.
Thanks in advance. I could really use some assistance with this. Right now, my watch is useless.
Same exact problem as others described. I ordered a replacement battery on Amazon for less than $20, which included tools required. It took about an hour of very tedious work to take it apart, replace the battery, and put everything back together. But it now works fine. No shutting down. And as another poster said, the screen discoloration is gone. The original battery was bloated to about double the thickness of the new one.
My back cover was cracked already, so in the process of removing it, it broke into 3 pieces. There does not seem to be a source for replacements anymore. So I'll probably just glue the 3 pieces back on and cover it with a body skin.
What is the Amazon link for this battery + tools?
I agree with those that believe it must be a software or update issue. I haven't seen anyone say replacing the battery resolved the problem. Has anyone tried that?
