jmk32
Does this battery grey out the battery meter at the top of the phone as some other non HTC battery's supposedly do?
I have the htc extended battery, something around 2700 mAh. It's awesome. It does add some girth to the phone but I don't care. It's so fricken nice to not worry about charging through a full day.
Sent from my rooted HTC Rezound
Yeah.. I would love that extra power, but I really wanted a battery that fits in the phone 'as is'.
Just personal taste. I like the thickness of the phone without having to add any more girth.. but that's just me.
I see your point, though!
On the stock battery, I'd only get about 6-8 at the most. 12 with the Mugen.
No, the new battery does not gray out the battery meter. It's just like the stock with just a little extra push of power. Everything looks and acts exactly the same, no bulky back, and was worth the buy to me!
However, it's been 12 hours, and I JUST got the battery is running low tone and message as I am typing this.
I finished the initial 12 hour charge, and used it briefly today ( a couple of hours of streaming). I can't give a full report on how much time I'll get out of it yet... but in answer to the above questions:
1.I only charge the battery with the charger, that works perfectly, though it seems to take slightly longer to charge.
2.Exact same size as the stock, so no bulging... fits perfectly.
3.Never felt hot, and I was streaming.
I just got it, so again, I don't know how long the average battery life is.
This is kind of on topic just a different point of view. I too like the current form factor (I usea a Seido Active case). I want the extra capacity but also don't want to be swapping batteries/back as needed. My normal day the stock battery is just fine. When I travel I need more during my day. Instead of swapping batteries I picked up a Motorola P893 power pack (capacity is 1820 mAh). It's slim at about 1/8" by 4" or so. Has a short built in cord that fits around the battery and tucks in at the micro tip for storage. When I need to charge I move the charger to my front pocket take the short cord out and plug into the phone while still on my belt clip and charge it. At night use the stock rezound charger cable and stock wall plug into the P893 and it will series recharge both devices.
My results were the opposite.
Well, my Mugen Power "1900" mAh (and I use that number skeptically) slim extended battery arrived and I've had a chance to run a comparative test on it. Charged it fully and used the phone till battery was low. Fully recharged it and then ran Netflix on 4g with full screen brightness. I did continuous streaming until the phone died. It lasted about 1 hr and 35 min.
I then ran the exact same test on the OEM 1640 mAh battery. I ran Netflix on 4g with max screen brightness. It lasted over 2 hours before the phone died.
Basically, my Muge Power battery got pwned :-(
Sent from HTC Rezound using Tapatalk.
