Hi, I have a Galaxy S10+ on Verizon in the USA.
Having a few major problems that I just can't figure out:
1. When I try to download apps from the Play store, the download gets to 99 or 100% but never completes the installation. The fix is to go into settings/apps/show system apps/download manager and "force stop." Then the installation will complete.
2. Some apps don't work correctly. For example the CBS Radio News app starts streaming audio, then stops a few seconds later. And the ParKing app sometimes records my location upon disconnection from my car's bluetooth, and sometimes it doesn't.
3. Notifications from all apps are totally unreliable. Sometimes they'll come right away. Sometimes not for hours, and sometimes all at once. And sometimes when tapping on a notification it will bring you into the app. while sometimes it will do nothing.
WHAT I TRIED:
Tried rebooting, clearing data and cache on problem apps.
Cleared data and cache on "Google", Google Play Store and google play services.
Cleared phone's cache partition.
Uninstalled and reinstalled broken apps.
I THOUGHT I FOUND THE SOLUTION:
All these problems went away a month or so ago when I logged out of my google account on the phone. Iogged back in and it all worked great! I thought the problem was solved, but now it's all happening again. Logged of the the google account and back in, but it's still broken this time.
AND:
I had similar problems with my Galaxy S7, and thought the new phone would fix these problems! Is it possible there's something wrong with my google account? How could I have the same problems on both phones?
I haven't yet tried a factory reboot on the S10+, but I did do it on the S7, and after working for a while, the problems came back.
Additional info:
Mobile data and wifi have strong signals.
No custom ROMs, not rooted or anything, just stock the way it came. Only downloaded apps from Play Store. Nothing sideloaded.
All battery optimization is turned off. Power mode set to "high performance."
I've looked everywhere for a solution but haven't come across anything that works. Thanks in advance for any help you can provide!
Your welcome!Thanks for trying, mustang 7757!
recDNA, I might try returing it. I wonder if Best Buy will be cooperative 6 months later.
jr154, I tried your suggestion of turning off wifi and rebooting, but it didnt help my notification problem.
Gayle, I might try what you suggested later, but I'll probably forget to turn airplane mode off when I leave the house!
Adam, I think you're onto something with the Google account. I'd make a new one but I have so much stuff associated with my current one. Do you know of an easy way to move calendar, docs, drive, maps, etc. to a new one?
Also, I thought I read a post where someone tried that and it still didnt help!
That's great !!Finally figured it out - it's the "Google" App. Thanks to this old thread for the same issue in 2017.
Thread: https://forum.xda-developers.com/ga...re-apps-reamain-100-downloaded-t3617403/page8
I uninstalled and disabled the google app, and have been golden since.
Glad the idiots at google test this stuff.
No not great. I recall this being a workaround and not a fix when I was trying to solve my problem and this is what ultimately made me jump ship to the Pixel. You should not have to disable this app to have core functionality in your phone. Personally it would bother me more to disable this app than it would to start with a new Google account or switch phones entirely.
I even called Google about it before I jumped to the Pixel and spoke to a human. This was a pointless exercise because the human simply typed words into a computer to document it. here we are two years later and it appears not to be fixed based on your problem and the lack of a solution that could be found on the internet.
I agree with you. My point being that I purchased an Android phone to enjoy the Android operating system and the Google app is part of the core functionality.The google app is not your google account - it's just things like the news feed and such. So I can live without it for a while. What I can't live without is my email notifications.
I agree though, it's ridiculous that this is a problem to begin with, and a problem that they have had BEFORE!
Wow, this is working for me so far... but yeah, I hate to lose the ability to use the google assistant. Grateful for now though!
Seems to be. At least for now! Google play apps install correctly, notifications work so far. One of my two broken apps is working again. Not sure what the deal is with the CBS News Radio app though.
