need some help PLEASEEEE
Quiquemaracas1234
Active member
Apr 9, 2010
26
I have flash clockmod recovery v.2.5.0.1 and I believe I have unrevoked forever, when I boot my phone the very top line says S-ON, I need to get the update to uncap the FPS but I tried to do so already following the unroot method from unrevoked but when I try to flash the pc36img.zip it says MAIN VERSION IS OLDER. SO when I try to run the uncap update I get a white triangle and a yellow exclamation above the android, I really need some help to get out of this unrevoked crap and be able to flash and try other Roms, I also downloaded The App ROM Manager, I try to download cyanogen 6 but when I try to flash it it brings me to the same white triangle with the yellow exclamation symbol.
Please please help me
Jacob.
VDub2174
Moderator Captain
Trusted Member
Dec 28, 2009
3,921
86
48
Not sure it'll work with unrevoked forever but have you tried the [How To] Unroot and return to stock guide then using the [How to] Rooting HTC EVO Froyo 2.2 (Windows) guide to get root back? From what I heard, the unrevoked forever method is permanent so I'm not 100% sure if those will work. (Someone correct me if I'm wrong please)
I used the unrevoked3 method (don't yell at me d3xn2o :p) and everything works fine for me. I'm able to flash ROMs and such without a problem.
2CupsWithString
passionately curious
Jun 1, 2010
2,762
412
Jacob, do you want to get the latest OTA or install a rooted ROM based off of the latest OTA?
And S-ON means signatures are on and I believe unrevoked forever turns this off.
CM6 is different than a stock kernel from HTC.
What is your goal here?
truslide
558
125
1. Did you actually achieve root?
Download Terminal Emulator and open the app. Type in SU. Do you get a $ or a #?
If you get a $ youre not rooted. If you get a # youre rooted
2. Did you perform a nandoird backup?
3. If you installed unrevoked forever you should have S-Off.
Something went wrong with your root somewhere along the way. If you have unrevoked3 and unrevoked forever, you should be fully rooted with s-off and be able to perform nandroid back ups and flashing roms.
Try to load into boot recovery and see if you have a nandroid back up. If you do, restore your phone and repeat the steps I mentioned to ensure that you have fully root and signatures are turned off.
Please tell your story on
this page
Good luck man, hope you figure it out.
truslide
558
125
When I tried with unrevoked3, i had root, but i was not able to get into recovery mode but I did have s-off after only rooting with unrevoked3. So it's strange that you don't even have s-off
Quiquemaracas1234
Active member
Apr 9, 2010
26
I do have nandroid and are able to do backups, in fact I restored a backup last night after I had my phone si screwed up trying to install CM6, I downloaded the terminal emulator and I get a $, so those that means I have no root?? And if it is that way how do I go about getting root!!!
truslide
558
125
Man... that's one soup sandwich.
You have nandroid but get an $. This is why unrevoked is trouble some. If I were you, I would do the following
1. Backup all your data with appbrain
2. Use liquidjesus' method for Unroot on a PC
3. Use liquidjesus' root method, I used simpleroot. Proved reliable.
After this you should be set. If you have questions PM me or hit me on gtalk.
The methods are in my sig
d3xn2o
2,242
125
Please don't unless you wanna get flamed..smh
Ice Cold flamage
2CupsWithString
Jun 1, 2010
2,762
412
I seem to always tell everyone the same thing in your situation and that's run the latest RUU (rom update utility) to return your phone to a pure stock image and then root it following the above guides.
edit: I would say though, about the above root method, I highly suggest using this guide: http://forum.xda-developers.com/showthread.php?t=741294 After you're back to 2.1.
This stuff looks like it's a lot more work than it really is.
2CupsWithString
Jun 1, 2010
2,762
412
Is no body gonna tell him that he could just flash a stock rooted rom ..
Never mind. Just run this.
*OFFICIAL* RUU_SuperSonic_S_Sprint_WWE_3.29.651.5_Radio_2.15. 00.09.01_NV_1.77_CNV_re - xda-developers
After you run that, you will be unrooted, and the update already applied.
Feel free to reroot the right way afterwards.
I asked when I posted on pg1, his setup seems to be a little unique so we got him setup with the RUU so he's at least on a clean slate going in to the root the "more right way".
igotsanevo4g
Retired Moderator
Jul 31, 2010
3,396
601
113
Nah go ahead and post ... Their flames are harmless they couldn't hurt a fly. It's all just entertainment. It's not like they actually write code or anything...
Can you write code?
Can you theme?
Can you use android kitchens to cook your own roms?
Can you use adb?
Can you even root the right way?
I can answer yes to all of those except writing code, which not many people can do anyways.
Troll on sir, troll on.
Reactions: Jerzyiroc
27scoob
162
Can you write code?
Can you theme?
Can you use adb?
Wow.. you got some thin skin.. I didn't ask you any of those questions... but I can so the same things that you stated you could... and like I said.. You don't write code... or have much of a sense of humor either... cheers buddy hope your day gets better.
Abdul Ali
