A
Android Central Question
So, I recently got an old Nexus 10 working again, after replacing the battery, had no issues, and the battery worked perfectly. So I was updating the tablet and the latest update was 5.0.2. So I downloaded that, and things went wrong.
Firstly, I could no longer press the digital home back or (whatever the name for the square one is) or swipe down to see notifications or options. Then, I update it again to try and fix the problem after trying some basic troubleshooting (USB had already stopped working at this point - keeps connecting and disconnecting when plugged in and when it stays, it doesn't allow adb to work.) So I update it and now all I have is a black screen on boot. It boots up, says optimizing app 1 of 1, and then just shows a black screen. the only ui that comes up is the power off one, and it plays a notification tone about 2 minutes into boot. So, I've tried reflashing it every way I could think of EXCEPT SP Flash Tool because I couldn't find a good file for it, though I assume that would work. Right now I've tried uninstalling and reinstalling the driver, multiple flash versions, using a different cable, using a different port, installing the USB software from Samsung's website, nothing wants to work.
