[Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)
willmon22
109
3
Re: [Guide][Port][WIP]Porting ANY OptiS rom to the OptiV in 1 Fla
What I am wondering is if you flash this then will you still be able to flash optimus v roms? Or are you stuck using optimus s roms?
nitestalkr
889
261
You only flash this directly after flashing an Optimus S rom to get it to function for the Optimus V, you can still flash any Optimus V Rom, as long as you do a clean install(always back up before getting format happy ;) )
Reactions: Nate456
Nate456
462
120
You can still use OV roms. All this is, is a fix for OS roms to work on the OV.
Reactions: nitestalkr
andrewnelson23
795
145
Nitestalkr I noticed in the op that you put that it doesn't work of you at zv9. But I know for a fact it does. I was using cm10 for awhile. I think gingerbread only zvj roms on the zv9 doesn't work. So maybe you'd wanna change the op to that.
nitestalkr
889
261
1am, huh? Ugh, fun times indeed! Glad you got them though!
Your G-1 first look video today was great! I love that you can add Folders to the Home screen and put stuff in it like your games. Sweet!
And change it I shall.
And apparently tapatalk still likes to take random quotes from random threads xD
And change it I have. :p
sent from my un-dead sammich.
topdawg661
333
70
Is mms the only major thing not work. I didn't see a "not working" list in the op
Edit: never mind reread works in gb thanks!
How would I reactivate my phone once I flashed a gb rom? (For data)
Sent from my Thrive using Tapatalk 2
sellers86
1,837
617
It does it itself. After you flash the patch of course
nitestalkr
889
261
Updated the OP, removed the CM10 animation.
added another patch for those of you that followed sammyz' guide to install ZVJ on the OV, and now you can stay on ZVJ and continue to use any ROM you wish.
jaredw444
173
13
Dumb ? Just wanna know if I flash to zvj, then I'd have to reflash back to zvd to use ov roms, or do I just have to flash zvj and that's it. Very nice work btw
denis870
