Problem Charging from Y-Cables that Appear to be Made for Charging
HumanJHawkins
4
I use a Samsung Galaxy S5 in a robot. Keeping robot and phone batteries charged is a constant issue. So I've acquired a bunch of different Micro USB3 to USB A Y-Cables in hopes of charging the phone from an on-board power bank while running the robot.
Multiple charging sources all work fine with normal (non Y) charging cables. Yet none of several Y-Cables work to charge the phone... It doesn't even matter if the data cable is plugged in. With the phone off, I can go straight from a reliable charging station to the phone using the charging part of a Y-cable and it fails. All I get it the periodic empty battery image on the screen as it starts to attempt to charge. Then it shuts off charging as though it detected something wrong.
Some of the cables I've tried are:
https://www.amazon.com/gp/product/B07N7WTW15/?tag=hawk-future-20&ascsubtag=UUacUvbUpU6560622
https://www.amazon.com/gp/product/B00P0C4M5M/?tag=hawk-future-20&ascsubtag=UUacUvbUpU6560622
https://www.amazon.com/gp/product/B005M0ICG2/?tag=hawk-future-20&ascsubtag=UUacUvbUpU6560622
https://forums.androidcentral.com/e...-000M7%3FItem%3D9SIA86V3E17988&token=jRtJ-m7P
Can anyone explain why this doesn't work? And more importantly, is there a solution?
Thanks in advance.
HumanJHawkins
4
If you mean what setting for data transfer, none... I can't even get it to charge plugged straight into a reliable OEM or Anker charger while using the charging side of the y-cable. Incidentally, it also fails in the same way attempting to charge from the other (data) side of the y-cables.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Old thread, but those are all cable for power to the external device, not power to the phone. What you want is called a USB charger hub. (But any USB hub that can handle the current and is powered by external 5 Volts should be able to handle it.)
andej
