problems with youtube on D-Charge
jono119
Active member
Oct 5, 2010
44
On my charge, the youtube app with play sound only. The video doesn't show up. I have to do a restart on the phone for it to work. Anyone else having this problem? I've tried to "end task" with the task manager and that doesn't work either. Only the restart works. My charge is about 2 weeks old, stock on ed2.
Thanks in advance,
Jonathan
Halcyon
194
6
I would try uninstalling it if you can and DL it from the market again. If you cant uninstall it just try re-downloading it.
Halcyon
194
6
Might want to take it into Verizon and see what they have to say. The extream thing you can do is do a factory reset. If there are any problems with the software this should take care of it.
Crunch140
Active member
May 23, 2011
26
8
Try this:
Settings -> Applications -> Manage Applications
Click All at the top. Open Browser from the list. Clear data and cache.
I was having problems with the browser telling me it couldn't play this video, and almost all youtube videos, where it had worked previously. I performed these steps, and it works fine again. Worth a shot as it doesn't appear to hurt anything.
dyslexicbunny
204
14
18
I've had the same problem from time to time. Restart fixes it. I've looked around online but nothing has been too helpful.
Sent from my SCH-I510 using Tapatalk
jkeene81
241
21
plus.google.com
i had the same issue but found out when i fired up the market that for some reason my phone didnt come with the most recent version of Flash, might want to check to see you have newest release
dyslexicbunny
204
14
18
I thought that too and updated flash a while back. It unfortunately didn't resolve the problem. Can other apps cause problems for flash? If so, is there a list of known apps somewhere? Thanks.
rezaking886
