Ok here's the deal:
I don't like the data2ext mod in general and I'm not the only dev that feels this way. It is an unstable mod that I never really wanted to support in the first place. That is why it is not included in the Rom itself.
I'm highly considering removing it from post#3 of this thread because almost all the issues that arise are from people using it. As a matter of fact, I just convinced myself to do just that. Sorry to everyone who uses it, but issues with data2ext are something I am not willing to support. Hence the warnings that I posted for it.
From this point on, if you choose to use a form of data2ext or apps2sd or anything similar, please don't post problems about it here until you have removed the mod and duplicated the issue while running this Rom in its native form.
This Rom is very stable folks, we are gonna try to keep it that way.
Not to mention to all of you... YOUR SD CARDS ARE GOING THRU TONS OF UN-NEEDED WEAR AND TEAR! Reading and writing that much info all the time is going to kill your SD cards MUCH faster.... just sayin...
Troubleshooting someones faulty SD card is much more than a headache...
This will not be supported in any of the future builds. You can do what you want from there to achieve this.
I understand your stance as a developer and would take the same approach. You shouldn't have to debug hardware, I think you should keep your stance on support 100%!
However, many of us require more memory. There are huge differences in solid state storage by process and by manufacturer. i've used flash chips on projects which would fail 1/100 block writes (but retries would work) and some brands which i've never seen an error.
To the general user, make sure you do your homework before you use a card for data2ext.
go to newegg, look at reviews. certain brands have tons of negative feedback, many DOA, many dying within 2 months... and you are right, the # of write operations is orders of magnitude higher for this purpose than something like a camera or mp3 player. so quality has to be #1.
can anyone characterize the read/write operations which occur? what is written, how frequently, to the same files over and over or does it make new files? If we knew approx how many writes per sector occur during an avg day while running data2ext, then we could calculate the mean time before failure of using an SD card.
if anyone knows what kind of flash is used for internal storage nand/nor/etc or better yet a part number, i'd love to see that to compare datasheets with micro sd cards. unfortunately from what i've seen, chips have very nice datasheets and SD cards do not, i have not seen any with write cycle testing numbers, only generalities.
thanks for any feedback helping the community use their devices with the power they would like.
*edited title*
