Retractable charging cable?
N4Newbie
Trusted Member
Nov 15, 2012
5,006
What's wrong with the one from Newegg? It has the correct connectors and generally positive feedback.
I have to add though, I don't see the value in such things. Buy a standard cable no longer than you really need (honestly, you can probably get buy with 12" - 18" for most uses) and then just roll it into a ball and shove it in your pocket. It will take up less room and have lower mass than any retractable device.
BlackAudiA5
154
I'm just trying to get away from the old "roll it up and stuff it your pocket" scenario. These are cheap.
flynempire
