[ROM][2.3.3][ZVJ] GingerRom v1.3 -4/14/12-
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
Alright well im just going to wait to hear more feedback regarding data before I go digging around in the build. The reports are too inconsistent for me to think something is wrong with the ROM. Data is a funny thing to pinpoint where the problem actually is. Location and sprints network is the unknown factor as well. If everyone was having the same problem, then I would for sure say I broke something.
pdxguy77
49
Re: [ROM][ZVJ] GingerRom v1.3 ***4/14/12***
noticed a weird glitch...maybe its me...normally when im in a phone call and pull the phone away from my ear my screen comes on...since i upgraded to 1.3 my screen doesnt come back on when in a phone call.
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
How much can i overclock my cpu on my phone? Max and Min?
It completely depends phone to phone. For the min, don't go any lower than 245. For the max your just gonna have to step it up slowly and you will know when its too high. You will get a lot of random freezes and reboots. I can barely hit 806, but can run 745 without any issues at all. Some people can't OC at all, anything above 600 and their phone gets pissed.
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
What kernel are you using and what are your clockspeed settings? Min/max?
pilot03
97
6
Went back to 1.2 and data is working fine again. I have no clue whether it is ROM or network issues. Just giving feedback. Perhaps it's just happening to a few people. Time well tell. Either way, I still think the work you are doing with this ROM is outstanding so far, despite this issue.
Reactions: jstntp
pdxguy77
49
Ok, try a dirty flash. Flash the rom and kernel together , no wipes.
ok.....when i put 1.3 on i did the rom after the wipe and then the krnl afterwards then rebooted....you want me to redo without the wipes?
pdxguy77
49
Yeah, right now just go into recovery and reflash without wiping anything. Rom then kernel.
doing it now
update...got it working....course thats with my wife calling me...its late to have someone else call me now..ill update if it happens agains....thanks for the help :)
Reactions: jstntp
ttenpas
58
5
My data is fine. I did a clean flash.
Haven't noticed any problems with my data either.
I just can't get used to the clock on the left side; looking forward to the mod to change that. Otherwise, I think you have a winner. Thanks for all the hard work.
Reactions: jstntp
biffsteele
10
"-removed wifi tether (get FoxFi from the market)" (changelog 1.3)
app not in market for me. found it via google, says it isn't compatible with lgels670.
( https://forums.androidcentral.com/e...pps/details?id=com.foxfi&hl=en&token=rQzlc4zI )
has anyone tried this to see if it did work or have any idea if it will hurt to try it?
or an alternate app?
thanks in advance
Just pulled this up from your link, it said incompatible. Further down it gave link to install it for Sprint users. Using it now to post this.
ryandubbz
83
17
Did you remove overclocking capabilities with your normal clock update? I can no longer oc my phone after current update
biffsteele
10
( https://forums.androidcentral.com/e...pps/details?id=com.foxfi&hl=en&token=FYWbdnxO )
thanks in advance
It works for me. Used your link, it said it was incompatible. Further down was a link to install from. I believe it was FoxFi Installer. Configured it and it worked.
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
( https://forums.androidcentral.com/e...pps/details?id=com.foxfi&hl=en&token=4ZIyeb1k )
thanks in advance
It has been reported that it does in fact work well with our phone, not sure why it says that in the market.
No, that mod has nothing to do with OC capabilities. Reflash your kernel.
Aitana135332
