[ROM][2.3.3][ZVJ] GingerRom v1.3 -4/14/12-
pdxguy77
49
Re: [ROM][ZVJ] GingerRom v1.3 ***4/14/12***
doing it now
update...got it working....course thats with my wife calling me...its late to have someone else call me now..ill update if it happens agains....thanks for the help :)
ok glitch is back again....grrrrr....:)
mobius1484
134
8
Probably have to disable it on gkernel then flash iscream
That's actually what I did. I felt like Gingerkernel didn't lock gps as well and drained battery more.
Maybe it's just me and I'm crazy. Lol
Still feel like stock kernel has the best gps.
mobius1484
134
8
Also wifi tether 3.1 beta 6 works. Have to set device profile to lg optimus and setup method needs to be NetD (Master).
Device may reset when you disable tether, but this is already a known issue and should work other than that.
Just tested their latest beta 12 and it works also.
ryandubbz
83
17
My phone after update is working fine, but my wifes phone after the gingerom keeps rebooting on its own.
Is there a reason for this, Also it is not overclocked
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
Honestly, if its not overclocked then im not sure why that would happen. Might simply try to wipe and reflash it again. Is she running one of drews kernels? If so maybe try without it at first or vice versa.
rcdoma
Active member
Jul 21, 2011
26
Flashed my wife's phone to GingerROM with stock kernel. Everything worked fine. The screen wake up time using power button with LG stock kernel was almost instantaneous, my phone with GingerKernel was a little slow. After updating wife's phone to GingerKernel, both phones wake up at the same time after pushing the power button (maybe about .5s slower than stock kernel).
Thinking of going back to the stock LG kernel on one of the phones. I couldn't find a stock kernel, would falshing the Community ROM load the stock kernel?
Zhara
Queendroid
Apr 4, 2012
891
200
Just re-flash GingerRom and it will give you the stock kernel back.
Reactions: jstntp
Buddlespit
Wannabe kewl
Jan 27, 2011
671
119
I've massively tweaked my v1.0 (framework-res.apk, systemui.apk, build.prop, gps.conf, init.d (data2ext)) and I'm kind of leery of flashing v1.3 over it. Your changelog doesn't really enlighten me on what changes you did, other than the wake animation. I guess I can pull all of the files I mentioned and compare them, eh? That would make your life easier.
I also guess that this was a useless post, all things considered....:p
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
If your happy with your version, by all means keep it. I did not do anything ground breaking in v1.3. The biggest difference is I removed some more framework bloat that may or may not make any real difference at all, lol. But if when you long press your home screen and the if pop up seems a bit laggy, that seems to be gone in 1.3.
Furthermore, you could just flash the script tweak I posted this morning a few posts back if you wanted to.
Reactions: Buddlespit
scifan
392
17
So... you wouldn't have a zip kicking around that would kill the wake up on button press (well, except for the power button) would ya?
res6jya6
115
5
I was about to grab the .kl file and modify it for you myself, however, I don't know which file the keys use. I would assume it's only a matter of removing the wake command from the home/settings/back/search keys.
I, however, rather like using those buttons as wake keys - the power button can be difficult to find at times.
kofasetic
48
:(After a couple of days with GingerRom on a freshly rooted ZVJ phone, the one issue that has re-occurred is the headphones cutting off via bluetooth like with ZVH. When I manually disconnect bluetooth, the pop up messgae appears and just sits on the screen. Need to reboot to get everything working again. Phone isn't overclocked and I am using Gingerkernel.
Anybody else having the same issue?
rickness54
