[ROM][2.3.3][ZVJ] GingerRom v1.3 -4/14/12-
ikeywatson
183
28
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
Look up the app from your pc and Read the "what's new" section of the app, says sprint removed the app from the market, lmao. That means it works!
There is a direct download link there now. Too funny!
ryandubbz
83
17
Re: [ROM][ZVJ] GingerRom v1.3 ***4/14/12***
I did the same rooting sequence to my wifes phone but her build number is different than mine, mine states Gingerom, but her build number says ZVJ and then some numbers after it. Why would this be?
ikeywatson
183
28
ryandubbz
83
17
i see what i did wrong, the ginger rom clock update was just a update and not the whole rom. So can i install the full ginger rom and then install the update over that, or should i transfer the updated clock files to the original rom then flash?
jstntp
/\C...D3\/
Feb 6, 2011
1,705
1,082
Right, ok you figured it out. Just flash the rom first and then anything I post in post #2 can be flashed afterward.
ryandubbz
83
17
Thanks for all your help guys both phones are flashed and running. So is it pretty safe to say i can run the cup at high 748 and low 480 or 320
Buddlespit
Wannabe kewl
Jan 27, 2011
671
119
You'll have to experiment to find the phones' max. It's different between every bodies phones. My first OptiS would max at 825, but the one I'm on now maxes out at 748.
I used to keep my minimum at 245, but I'm trying 320 to check responsiveness out of sleep.
Sáenz
