rockman73
Hi folks - Does it matter when I root the Virgin Mobile LG Optimus Elite: before or after the required Essentials with Mobile ID firmware update?
in superuser when I click to update....everything loads and updates well, however one thing seems to keep happening. "copying su to /system_ fail!" happens each time. I have downloaded busybox and superuser fixer, but to no absolute avail.
But that sadly didn't seem to correct it.try uninstalling original superuser and then redownloading from market. ill ask around and see what the cause is.
..and that didn't seem to make a difference either.I turned on usb debugging and then it went though. Give it a try and see if it helps.
First off this method was created by giantpune of android forums and I take no credit. This method is listed as beta for the time being but as far as I can tell it works fine. Ive used it on my optimus elite without issue as have many other elite owners. But for the sake of saying so,what you do with your device is up to you. If you brick it not following the guide (with this method I do not see how you could..but anything is possible), you are responsible.
Prerequisites : New elite owners should update their device with the LG update before rooting. This will prevent the need to re-root after update. Users who have rooted with any other root method who have returned to stock root using the jcase root method should update using the LG update to prevent the need to reroot after update. Otherwise anyone using any other root method including jcase method,does not need to root using this method. YOU ARE ALREADY ROOTED. Why use this??
Step 1 : Download Ministro II.apk provided below and install it. Let it update and get what it needs.
Step 2 : Download poot.apk listed below and start it. Click "press here to poot"..it happens almost instantaneously. Probably wont notice much except the log output.
Step 3 : Click "get superuser". This will open google play store to download superuser. If play store doesnt load it correctly,stalls,or just goes to default play store home screen,type superuser in search prompt and it will provide the superuser download page. Install superuser,open it and move to the info tab click tap for updates and let it update,depending on your connection you may get a fail. Dont worry try it again. Superuser should update the binary for su and you are pretty much done. You can download root check if you like from play store to verify. Or you can use the poot built-in root check. screen shot is provided below to show you the output for a successful root. After root enjoy and if you meet giantpune on android forums or here. thank this individual for providing this extremely simple root method. Trust me,using the other root methods vs this is a task. So a thank you would be deserved.
