Samsung Note 10.1 (2014) requires USB plugged in to stay powered on.
A
AC Question
I have a SM-P600 device. Had the device drain battery and not power on at all.
Replaced the battery and was then able to plug it in and see it charge.
Once fully charged I powered on the device and all worked fine.
But when I in plug (with 100% Battery) it will go to black screen and power down.
Tested it several times same result. Unit must be plugged in to work?
Anyone have suggestions? Unfortunately it's out of warranty?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
Welcome to Android Central! I'd open it back up again and make sure none of the connections are loose, and that the battery was installed completely correctly.
Mrjhe29
