Unfortunately, there is probably nothing you can do if you are a guest at a venue who is unable to access the WiFi network and the venue doesn't fix the problem. Since you aren't required to have access for your job, and it's not your own personal network, there is little incentive for the venue to take action. You could try contacting them via social media and mentioning the problem. If many other people do the same, then they may be more inclined to troubleshoot it.
Well.. a couple of things. I'm pretty sure this was stated earlier in the thread, but just to recap:
1. The Wi-Fi at the Chase center works fine when connecting in 2.4GH and 5GHz, but connects and disconnects constantly on 6GHz. (so not restricted access)
2. This has happened NOT just at the Chase center but when attaching to other 6GHz capable AP's
3. The issue is NOT just happening on my end, but other people (likely not trying to connect to Chase center) are also having the issue.
4. Samsung has mentioned this issue on their web-site as well so they are aware of it.
"Connected without internet."
www.androidcentral.com
-right now the fix is to upgrade to Pixel 8.
5. My friend also has an S23 which will not connect to 6GHz.
I'm thinking it's really time to stop trying to find fault with everything else, and face facts, that Samsung face-planted on 6GHz for this device.
