ARCHIVED: Scott Pilgrim ROM for OV (CM7 Gingerbread, Zefie Edition) [WIP]
Status
Not open for further replies.
nba
Active member
Mar 11, 2011
31
Re: Scott Pilgrim ROM for OV (CM7 Gingerbread, Zefie Edition) [WI
btw if you use my method, its not aosp that you're running, it just says that because of the sprint-to-ov.zip that you flash. if you dont flash that, it will have the original creator's name, but will also say sprint everywhere instead of virgin mobile.
bjones72751
183
3
Oh ok, so do you know what rom version or kernel it is? Also I figured out where I went wrong installing aosp. I forgot to flash the damn gapps. My whole problem right there. Idk why I didn't think about it. Noobs will be noobs I guess.
nba
Active member
Mar 11, 2011
31
i forgot the rom version, i know the mod is cyanogenmod 7.1.0, and the kernel is xionia 014
sblood86
426
103
2.3.3 if I recall, he ported it to the S first check the thread there for any certainty.
bjones72751
183
3
I looked. Its 2.3.4. I just noticed something interesting. You know how the keyboard doesn't doesn't rotate, just closes? Well, I was on the amazon app, which has a glitch that causes the KB to stay displayed if you touch the search bar then press home. When the KB was on the homescreen, guess what it did? Rotated! Ha, explain that one.
Edit: to get the glitch, go to amazon start screen, press in the search, then press home key. Mine leaved the KB up.
JerryScript
Daydream Believer
Mar 8, 2011
2,055
1,559
So what your saying is there is a full functioning aosp mod on this "scott pilgrem" thread, but not the aosp thread? That's funny
Actually, this ROM has pretty much the same bugs as the aospCMod ROM, here's the latest list edited yesterday:
http://forum.androidcentral.com/1077006-post235.html
It's good work, but not the answer yet.
Raul720
167
11
So I like the ath3no rom except for the launcher. I hate adw. Anybody know a way I can get the stock launcher to be the default. I've tried moving over launcher2.apk with terminal but i have to launch it manually and as soon as I reboot adw becomes the default again. Should I rename launcher2.apk to adw.apk and replace that. Does anybody a way I could completely remove adw and just have the stock launcher?
mjs2011
1,059
73
So to those using nba's steps, would you say that this version is better than the current AospCMod version that we all know so well?
Sent from my VM670 using Tapatalk
Raul720
167
11
You can use a root app remover and get rid of adw
If i do that whenever i restart my phone there wouldn't be any launcher. Do you where i could change what launcher to load. Like is it in a text file or xml or something.
riggerman
568
72
Go to manage apps and scroll down to adw launcher. Make sure the default is turned off. Return to your home screen and set the launcher of your choice to default.
pbailey212
765
219
I'm sure the stock launcher is there, download home switcher from the market, it might work
Kreatur3
660
40
I will have to restore my backup I thought it still had the stock launcher
Raul720
167
11
Ok I managed to get the stock launcher working.
I used this launcher and i renamed it ADWLauncher.apk and used it to replace the old ADWLauncher in system/apps/ .
Status
justinedwards
