Sd card issue
beperry1
169
26
Anytime my phone takes a tiny bump, my sd card unmounts then remounts and sometimes says its damaged. What? Help please...
Ouch...it's a Razr, Maxx.
beperry1
169
26
carracerz14
1,374
95
Make sure it is actually all the way in. It will click to lock on place. You may need to use something small to push it all the way in. I had trouble getting it in as I don't have long fingernails.
Sent from my RAZR MAXXIMUS ;)
carracerz14
1,374
95
It's in but still malfunctions.
There's a teenage boy in my mind laughing right now.
Yeah I laughed as I was typing too lol.
I would give verizon a call you probably need a replacement. There might be something wrong with the sd slot
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,618
4,760
113
Are you sure the SD card isn't the faulty item? If you have another device that accepts micro SD cards, try it there to see if it works. Or try a different SD in your Maxx.
Sent from my DROID RAZR using Android Central Forums
carracerz14
1,374
95
I would think that if it were the sd card it would either work or not work, he said when he hits a little bump it does it. Makes me think it's something with the connection in the phone, but give it a try in your computer or another phone.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,618
4,760
113
Look at it this way: a like new or refurbished unit that works is much better than a brand new one that's buggy. I've experienced this before with my previous Droid Incredible--the refurbished replacement worked and looked just fine.
