I have setup the splashtop on my computer and transformer and it works fine on my home network. Does anyone know how to get it to work on another network?
OK on the TF did you set up a second 2nd access portal? You can not use the same one you use toYes, went to appilcation and gaming then selected Port Range Forwarding input 6783 6785 Both then my computer's ip address then checked enable. Then save
