is there a way to tell if the nonvoodoo test 5 is active like see what kernal im using? and is there a place to find common issues with test 5 and what it offers I was in another thread that suggested 5. I am using all stock stuff except for that list i gave you is there anything i should do or that you would suggest?
I have this same question. I see no difference when the phone loaded up and am wondering how I can tell if test 5 is really loaded properly.
When I installed test 2, I knew right away since the phone looked stock and I had to reload my stock settings. When I loaded test 5, the phone looked exactly the same.
Especially wondering since it didn't fix my cd-rom problem.
I want to flash froyo, but I am reluctant to since I use wireless tether sometimes and I worried about the "Tattle Ware" (not my words) that Verizon has put on it. Since I don't really use it alot, I think I may just update and not worry about it. Others are using it and have not had the Verizon Police knocking on their door.....yet.
