jondevere
just look for all your signal png's. There are roaming ones in there where it shows the signal bars with the triangle...Hmm. I've never actually seen the roaming triangle that you're talking about in action. Any chance you can take a screenshot of the triangle? Is it located in the status bar? It should be an easy fix, I just need to know what to look for.
I know its lots of digging, BUT ALL the signal images are in the same place. Find them and you will see EXACTLY what he is talking about.
As for if its in your mom... Im not sure, personally not using it for calls ATM.
