toddbee
The apk file does work and fix the searching, but once you reboot it goes away and needs to be installed again. Is there a fix for this?
darn..you are right
i don't know...
maybe to root and replace the system file with the old one?
double darn, I'm rooted and it doesn't persist
Same here. Just got the SGSlll. Still learning how to use android. WebOS so much easyer to use it.Glad to see a resolution. I'm moving from WebOS to Android at the beginning of August and I would miss the ability to search for contacts/apps/and web at the same time.
Got my GS3 in the mail this morning and it updated. Now it is saying there is another update. Was the first update a previous and this one is the newest?
If you are rooted, delete the old search apk in the system/app folder. Install the one posted here in your system/app folder. Boot to CWM and fix permissions. Now it's there even after rebooting.
________________
Just Flash It !!!
________________
Just Flash It !!!
A possible workaround could be using Gesture Search. It still has local searching of contacts, music, etc..
can you elaborate on how to fix permissions? thanks
it fixed it for me...and others...
