Update #2 L710VPLG2
GK3K
229
21
I am just now noticing that when I long press the menu button and start typing Nav (for Navigation), only Google search results are displayed.
So, did this last update remove universal search?
mrdynamite
If you got used to this feature, its a pain in the butt to lose it, especially that if you want to search contacts, you have to go into contacts, then search, versus just using the global search
to fix it, install GoogleQuickSearchBox.apk
here is that file
I was able to install successfully, thanks!
bdmridgback
499
32
Not rooted here and successfully added the old google search and got my Google bar functionality back .
FU Apple!!!
Posted from my Sprint White GS3 via Tapatalk
SprintGuy
14
Hey Guys,
I've gotten the "Security Update" (and yes my Google Search is busted), but...I have a much bigger issue and am wondering if u guys see it too.
I've noticed much worse battery life. Also, my SystemPanel monitor show a consistent CPU usage of around 5% no matter what, even when the phone is quiet for a bit.
Even worse...looking at the processes running via Quick System Tools, I see a VERY persistent process of the following label:
Android System
- DrmEventService
This thing NEVER quits and it is always registering between 2% & 5% day and night.
It appears to be something related to copyright protection on like movies and music, etc.
Could it have been added with the update? It didn't do this before. Reboots don't kill it either.
I did call Sprint support, got to level 1, rep didn't know about it, but he called "somewhere" and they did know about it. Got over to level 2, they didn't know about it, they wrote it all up and were sending it on for further testing.
U seeing anything guys???
Tkbredx
2,101
58
Feels like my battery life is better and the phone charges faster since the update. Thanks for the search apk. Installed it successfully
Skunkape60
4,460
344
exactly..
it used to before the update
If you are rooted it's easy enough to add it back. Using a root file explorer such as root explorer or es file explorer, copy the attached file to your system/app folder (make sure you authorized read/write. It should ask if you want to replace the current file. Say yes. when it's done re-boot your phone and the search you had before the update is back.. Very simple...
If your not rooted you can still use this to get your search button back by downloading the attached file to your phone, click on it and choose install. It will work but you will have to redo it every time you restart your phone
kgilbertsen
461
7
18
FU Apple!!!
How do I install the old Google search file? I've been avoiding the update so I don't lose the search function. I've got the old file downloaded, but don't know how to get it installed. Can somebody explain how to do that? (And I mean e-x-p-l-a-i-n, since I don't have a clue) Thanks.
Gator352
Banned
Sep 11, 2010
3,742
50
This is why I love android! Apple sues. Wins. Google makes appropriate changes. But changes can be reverted back due to killer developer support! What a slap in the face of apple with the right hand while giving them the finger with the left!
Awsome!
Skunkape60
4,460
344
if you're unrooted the best you can do is download the file provided. Click on it. Choose install when it opens. It will work regardless of your root status. But you would have to do it every time you reboot your phone.
The only way to get it to stay is by replacing the app in the system files. The only way to do that is by being rooted.
So while you can get it working being unrooted, it isn't a permanent fix. For that you must be rooted.
________________
Just Flash It !!!
Reactions: kgilbertsen
Skunkape60
4,460
344
FU Apple!!!
Could you tell us how you did this without being rooted? Have you restarted the phone yet and does it still work? Not to be a party pooper but to load it and make it stick, it must REPLACE the apk in your system folder and for that you must be rooted.
________________
Just Flash It !!!
kgilbertsen
461
7
18
if you're unrooted the best you can do is is download the file provided. Click on it. Choose install when it opens. It will work regardless of your root status. But you would have to do it every time you reboot your phone.
Thanks. I guess I could just email the file to get it from the pc to the phone? I don't think I'll be rooting the phone right away - you see how much help I need just getting a file onto the phone...
