Flashed stupidfast kernel. I think. The one with the usb connection issues. Long story short bricked phone. Using odin3 to reinstall dl09, but phone won't stay connected long enough to install. My phone will only boot to recovery screen. Please help.
First make sure you have the
latest drivers
Second, change USB ports, try the ones on the back of the computer that are closest to the motherboard
Next disable any antivirus programs as they disrupt the flash
Pull out the battery and leave it out
open odin , insert file in PDA
plug in device and hold down the VOL down button till it goes into download mode (The batter should be out during the entire process)
once in downloadmode wait for it to connect then hit start
IF you are having trouble with the battery out then pop it back in but ideally it should be out
