brainless#AC
Active member
ive been holding out switching roms waiting to see if they build a 4.1.2 build . Been on the 3.6.6 for a few days now . Poor batt life and the clock speed keeps reverting back to 700MHz
Been dropping in at CNA's forums every so often to see if anything is brewing for 4.2. I had been pretty quiet over there. I figured he was probably waiting for CM to release a stable build to work with, but the site has been down for a couple of days now.* I hope he isn't bagging the ROM because I think he does a nice job putting them together. In the mean time, you can still download the latest 4.1 builds from the download site.
* Yes, he builds on CM and they had issues with him, but he was giving proper credit with his latest ROMs. He even provided a way for CNA users to donate to other projects IN his ROM.
I'm sure you won't see anything from him until both CM and AOKP start publishing their work on 4.2 to github. Unless he just ports some of their older ones to it first.
Right. I wasn't expecting to see anything yet, but I didn't expect the site to be down either. Probably nothing to it.I'm sure you won't see anything from him until both CM and AOKP start publishing their work on 4.2 to github. Unless he just ports some of their older ones to it first.
I look at these ROMs the same way I look at hamburgers. Some days I like Five Guys, some days I like In-n-out. I don't have a "loyalty" to any one ROM just as I don't have a loyalty to any one burger. If someone else makes a good customized 4.2 ROM then I'll give it a try. Doesn't mean I've "moved on", just means I was in the mood for something different. I'll be back when the CNA mood strikes me.
Tweets
16 Nov Codename(Android) @CodenameAndroid
Just want to let you know I have 4.2 up and running making plans for the upgrade
Collapse Reply Retweet Favorite
