[ROM][4.1.1][AOSP] Codename Android 3.0.0 [JB][07/31/2012]
MRW1215
798
15
Hm. I guess my typing problem isn't CNA-specific, because I have the same problem on my tablet, which is running a completely different JB ROM (and was "clean flashed"). I wonder what causes this issue...? That's pretty annoying.
pmcd1962
84
6
I recall an earlier post someone mentioned lag time with the unlock screen, which I had not seen until now. Running 3.4.0.
VAVA Mk2
364
12
3.4.1 has been rock solid for me.
One suggestion for the OP would be to just link Verizon GN section of Codename Forum so you won't have to update the OP here with each release. It's easy enough to look in "ROM Releases" for the latest version.
Galaxy Nexus Verizon - Codename Android
Will add their forum link. Unfortunately, you will still need to go to their link (CNA's page on goo.im) to download each update.
VAVA Mk2
364
12
Fixed the links on the OP and will basically for each new release just update the info for the new version. All new versions of GAPPS and the ROM will appear in the links provided and there is a direct link now to the GNex VZW Rom Releases forum at CodeNameAndroid.com :D
pmcd1962
84
6
Did a clean install of 3.5 and it's great. Best CNA ROM yet.
I have a problem toggling the torch from the lock screen. It will turn on but not off. I end up having to reboot.
Also the timer does not clear from the notifications drop down menu.
Other than that I really like the new features.
henryricherd
