Simple math is why...... Phones with SD-Card slots almost invariably hold more total data than phones without....
Even if this phone has 32gb on board (which is on the high side for phones today) it still has at best identical storage to a 16gb phone with a 16gb card stock, and is a full 16gb behind when you upgrade to a 32gb card slot...
Imo, there is no upper limit on how much data you can have on phone.
I'm hoping the battery can be removed for those times when a true battery pull is needed to get things working again.
My Samsung battery is sealed on my tablet, and there are no reset buttons.
There were times when things froze up, and I had no way of getting it back up and running right away.
I tried the combination of the power button and volume keys as the method for reseting. Most times it will work right away, but then there are times it won't.
Thinking I would have to send it in to Samsung for repair, it would start back working as it should after a while.
I'd hate for my phone to have to go through the same ordeal.
Sent from my GT-P7510 using Tapatalk
You do know if you hold the power button that it will reboot, right?
Sent from my amazing galaxy tab 10.1 which also eats ipads
i wonder if that is why it has the tiny little power button on the side of the phone in the renders. a mechanical power button for the battery pull situations. i can almost guarantee you that isnt the power button for turning the screen on and off.
Here is something that nobody has mentioned. If the battery is non removable you can actually fit more battery into the phone. If you have ever seen the battery packs for iPhones you will know they are smaller and thinner than an equivalent removable one as they don't need the protective outer shell. What if Samsung has filled all available space in the casing with battery (like in the latest iPhones) that, along with better power management and proper usage of dual cores may mean you don't need a backup battery.
Troll thread??
This is a legitamate concern. I'm a travel type and having spare batteries is pretty crucial to be able to tether for work and entertain myself for long periods.... and still be able to call your ride or the office when I reach my destination. An outlet is not always available folks.
**and i was so freaking hype until I read this gotcha**
I think the lack of a sealed battery is most over-hyped and tired arguments there is. Certainly valid a few years ago.
There is a reason LTE phones have: a) pitiful battery life b) turn into bricks when used with an extended battery (I will say the Bionic's ext battery is not that bad). You can put more battery into a phone that has a sealed battery than one that needs a frame to hold a replaceable one.
@sblantipodi
I got a New Trent Super-pack IMP500 5000mAh External Battery pack from Amazon in 2010 for 41.95 (no tax).
It wasn't that expensive, not that big, and worked well when I needed.
Additional bonus... I could use it with my other electronics if needed.
You mentioned tethering, why not usb tether? I don't think I ever tether without plugging in except for maybe very short periods.Troll thread??
usb tether generally requires drivers or software installed on the device that needs the internet connection and this is not always possible.
