Results 1 to 11 of 11
- 12-27-2012, 11:20 PM
Thread Author #1
- 12-27-2012, 11:38 PM #2
Re: A few issues with my note II
- 12-27-2012, 11:44 PM #3
You do not need root for more apps in MW, XDA was the OG with that, and you have burned 15% in three hours? You are on course for 20+ hours...seriously?
★★★★★ - 12-27-2012, 11:45 PM
Thread Author #4
- 12-27-2012, 11:46 PM #5★★★★★
- 12-28-2012, 02:44 PM
Thread Author #6
- 12-28-2012, 03:49 PM #7
Andrew welcome to the Frat. I am becoming the guy with all the questions and the issues so no worries on the noob part. haha
Sent from my Unlocked Galaxy Note 2! - 12-28-2012, 04:10 PM #8
Andrew, maybe this will help you out. I got my note 2 on launch. I synced gmail accounts and one exchange account. The exchange account if left on push for peak and/or off peak settings, keeps the sync on, causing excessive battery drain. I had to change the sync setting for the exchange account to check every 5 minutes instead, and that solved that issue. Gmail is fine. Battery is all good. However, I have had the phone say that it cant log into exchange account due to a password issue. This phone has something different with syncing and exchange that messes with it. Not much info out there about it yet that I found. I run the same account on 4 different android devices and the s3 and note2 are the only ones that have the issue with the same exchange settings. I can leave them set to push on a galaxy nexus and touchpad with CM9, but not the s3 or note2. So long story long, are you having issues with an exchange/active sync account?
Sent from my SCH-I605 using Tapatalk 2 - 12-31-2012, 02:55 PM
Thread Author #9
very helpful. I have thought about the syncing between almost all accounts. i cut the syncing to manual only on the standard email app and now i am at 94% running on 2hrs and 33minutes. I also had youmail running which i hear can be a battery killer! I like Gmail more as well. thanks!
- 01-01-2013, 05:24 PM #10
- 01-01-2013, 06:08 PM #11
First off you appear to have at least 1.5 hours of screen on time over the course of just about 3 hours. The screen is the number one drain on your phones battery so the fact that you only lost about 15% with that much usage is mind blowing. Also the brighter your screen the worse, so dim the screen to the very minimum to really stretch out how long you can run on the battery. But either way even on max brightness you will get a solid 4-5 hours of screen on time, which imho if you're putting in 5 hours of screen on time on an average day, then you need to get busy lol.
Samsung Galaxy Note 2 on Verizon
Jelly Beans Build 16 - Perseus 36.3
Need some help with a few sound setting in my Note II
By GirlWithTea in forum General Help and How ToReplies: 1Last Post: 11-16-2012, 10:52 AM -
SD card issues with my Note
By wildmangk in forum AT&T Galaxy NoteReplies: 10Last Post: 08-30-2012, 11:35 PM -
Annoying Issues with my Note, apps forcing closed, Shortcuts hang
By enduser2941 in forum Samsung Galaxy NoteReplies: 5Last Post: 08-22-2012, 12:09 PM -
First few days with my Galaxy Note
By planoman in forum Samsung Galaxy NoteReplies: 40Last Post: 01-27-2012, 04:15 PM -
Hey guess what? I haven't had any issues with my evo.
By Booshanky in forum HTC EVO 4GReplies: 7Last Post: 07-07-2010, 10:48 PM
Reply
