Pandora bluetooth issue Dodge Ram
reb0957
304
8
18
I constantly get really crappy audio from Pandora over BT. I can use my siriusXM app and get crystal clear sound via BT. I am trying to figure out if it is a phone issue a truck issue or a pandora issue. I have recently down loaded the bad *** customs pandora app and it is the same thing. sporadically crappy audio via blue tooth. Is anyone else experiencing this and do you know a fix?
TIA
mountainman
760
18
Do you have Pandora set for high quality audio?
Settings - Advanced - higher quality audio ON
Sent from my small screen iPhone 4 using Tapatalk
brandonv79
Active member
Feb 4, 2013
39
^ What he said. I had real problems with the sound with my Bluetooth headphones because of this setting being low quality. I had to re install it for some reason and it defaulted to low. Hope this does the trick for you. And off topic and as a huge Dodge fan obviously it can't be a truck problem. I can't wait to get the Crew Cab. only 4 more years. Ugh.
