Android Tablet 4.4.2 : Hi I have been to all the forums looking for a solution to this problem. Have tried a new ROM install. I did a recovery Boot. I did a factory reset. Both hard and soft reset. Problems tablet won't charge, or hold a charge, I can't get past OK System UI has stopped error message. Every so often if I connect my USB flash storage drive it will open up storage settings while still flashing continued UI stopped working OK message. Also during this step UI will start and stop just for couple of seconds. Sometimes the lock screen will appear but the UI is not working, with continued OK UI stopped working message. Please if you have any solutions, I need your advice. Thanks
