To elaborate a bit on my previous post.
Let me be clear--I do for the most part take responsibility for self-education. I know more than a lot of the "newbie" types, insomuch that I know how to side-load apps and to create .apk files out of something like File Expert. I have owned rooted devices before and learned how to make what I'd call a "system image backup" of the device in its current state, apps and firmware included, to where, if I had such a device, I'd likely know how to revert such a device back to "stock" very easily. (A side-note--if phones are supposed to be like computers, why not supply a "restore" image on microSD similar to how computers used to have restore CDs and later have had restore images on their hard drives?)
Speaking of "system image backups," I perform them all the time on my various PCs with Acronis System Image Home 2010. I will create a system image of a PC upon receiving it in its "out of box" condition as well as making an update or two as programs are installed. Then, I am able to, for instance, fix my wife's computer when its hard drive failed by swapping in the new hard drive and getting everything back quickly via a system image restore vs manually installing Windows, activating it again, installing all the programs again, etc. I know these things.
I know these things, yet even so, the typical instructions I see in here for rooting a device or rolling back to a previous ROM etc--I can't understand them. They're EXTREMELY complicated. With expressions like "just use the previous .bat this or .exe that and push the .ini through to the reconfigured RAM chip found on the back of the SIS nobe"--I'm like "WHAT??" I have no idea what any of that is.
Look, I get it, you don't want to have to spell out things TOO painfully, as if you are saying "the power button is what turns your phone off/on, it's located to the right, you have to hold it down, it's not like a light switch." I've dealt with such people, yes, it's annoying. However, there's also something to be said for not talking over people's heads like they are someone who is supposed to know how to BUILD the thing. I appreciate tips I receive, such as when someone told me that in 4.4 with on-screen navigation buttons, you DID have a menu key, just hold down the recent apps icon, that did double-duty as menu that way. I never would've known otherwise.
These people aren't trying to "pimp" their phones or get too fancy, they just want to do a simple factory rollback to stock ROM (see, I know some of the terms). In prior days you could easily do that with a CD on a computer. Something that simple is needed here, in terms of the explanations. They're not trying to do the PC equivalent of writing HTML and Java web pages in a text editor or write machine language or Visual Basic scripts. (Yes, I've done Visual Basic scripts, and yes, I STILL can't understand half of these tutorials.)
