bjrosen
My 6P is doing fine however I didn't do an OTA, I installed the factory image which has the side effect of doing a factory reset. Try doing a factory reset, that might fix your problem.
Certainly seems reasonable since the N6 display is bigger and all of its components are a year older.I wonder if there's a difference in battery life running developer preview 5 on the 6p vs the 6 regards of screen size, and battery size though.
I've read battery life complaints about both the 6 and the 6P as well as the 5X either here on AC or on Reddit.I'm not Sure if people here are complaining about the battery life on developer preview 5 with the 6p or the older 6.
Battery stats aren't advising so far of apps using the battery. Running this on a Nexus 6. Worst performance of battery I've ever seen on all releases since day one of Nougat being available
As the title suggests, just installed the latest update and my battery is now going to be empty in 3 hours.
When I installed the update I was at 91% and it's now at 60% in an hour.
None of the versions prior have had this issue
That was my experience with DP 5. Battery life on my N6 seemed to take a minor hit immediately after the update, but all was fine again within 72 hours or so and after a few top-ups on the charger. Sort of an extended optimization period.Maybe the phone is still adjusting to the new OS.
