Android Central Sideload Wonder Machine v. 1.2
DroidXcon
11,102
3,392
I seem to be having a really stupid issue (I hope)...I run the swm in both admin and non-admin modes (win7), and when I click the install button the command line opens. However, all it says is 'C:\AC_SWM>' with the flashing underscore after it...when I hit the troubleshoot button the same thing happens. Im pretty sure its not a phone issue since I have debugging on, the usb mode is set to 'none', and I have .NET Framework 4.0 installed. Can I get a bit of help please? I will root it if I have to, but the only reason I would want to is to side-load apps.
Did you use the installer?
Sent from my ADR6400L using Tapatalk
egyptiangodset
do me a favor
  • with your phone in debugging mode and plugged in
  • go to your windows start button, click it
  • when the menu pops up either hit run or in the search window type CMD
  • then type cd C:\AC_SWM
  • once it changes type adb devices
ok, did that, this is what i get:
* daemon not running. starting it now *
*daemon started successfully *
List of devices attached
TA2070AI9B device
C:\AC_SWM>
egyptiangodset
essentially when you use the troubleshooting for testing drivers it does the same thing that i had you do with adb devices.... have you tried to uninstall and reinstall SWM?
just tried it, no go. im wondering if its a file -extension issue because originally i had to switch the default program for .bat's from notepad to command prompt (my comp changed it for security reasons), maybe something else was changed that i dont know about?
DroidXcon
11,102
3,392
yeah those files need to be batch files. try downloading Notepad++ , open them using that program and save them as batch files
egyptiangodset
Try ruining the usbdiag..if that does not work maybe we can screen share see if I can find the problem
thank you! your idea inspired me...i managed to jerryrig it by just doing the command manually. I loaded the app through the program so that it created the to_install.apk, then when the command line opened up i ran the loader.bat and that worked...dunno why it didnt do it automatically but its def better than not working at all, so thank you!
rtmartinez24
10
I am using a cappy from AT&T. I installed SWM and it is working. I was able to install the amazon app store app but i still cant install programs from the that app. where can i find the apk's for programs i have downloaded from the AAS?
kurioskurion
79
Device Not Found
thanks for the app. Hope I can get it connected.
Was able to install the SWM to Windows 7 perfectly fine.
I'm running an Inspire 4G.. set to charge only (also tried HTC Sync & Disk Drive) phone is set to Debugging
I've tried both usb ports on my laptop and two different usb cables.
SWM still cannot see my Device.
any ideas?
core132
I have a windows 7 and a AT&T ATRIX 4G. I've had the phone for a week, and I'm new to this stuff. When I try to install the .apk, I get an error saying "device not found". I have no idea what to do. Maybe I don't have a driver, but I don't know how to install them..
uhfive
Thank you!
I have had every iPhone since day one. I waited overnight in line for the first one, I worked at an At&t store shortly after that and the day the 3G came out i had a friend buy one for me (as employees we weren't supposed to have them), I bought the 3GS the day it came out, and the iPhone 4 i had to work so my wife waited in line for almost 7 hours to get one for her and i...Jailbroke every iPhone i had, i figured rooting couldn't be much harder. I "soft bricked" my Atrix the first day i got it. that put a bad taste in my mouth about Android on day one. I tried this whole side loading app that same day, but i found it from a different source. It worked about as good as a butter knife would at cutting a 2x4. I gave up...thankfully i was looking for some new apps online today and came across your post. Thank you is all i can say, I only wanted to root so i could sideload apps (Amazon App Store) didn't see the possibility of another brick as a good trade off. Your app worked wonders. I can truly say that you have saved me from switching back to my iPhone. I appreciate your help and this websites wealth of information!
tivativa
