A Android Central Question Jul 6, 2020 #1 wish i never got it, dont use the bixby, drops calls , just a real disappointment.
mustang7757 Super Moderator Moderator Feb 6, 2017 91,590 6,174 113 Visit site Jul 6, 2020 #2 Hi, Bixby can be disabled, drop calls could be issue with your carrier. I'll leave a Link so you can communicate here I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply https://forums.androidcentral.com/showthread.php?t=409154 Upvote 0 Downvote
Laura Knotek Moderator Captain Moderator Jan 8, 2011 11,796 4,081 113 Visit site Jul 6, 2020 #3 Welcome to Android Central. What carrier do you have? How is their coverage where you live and work? Are there any issues with towers nearby being serviced? If you don't use Bixby, then you can purchase Package Disabler Pro to disable it. Please join us as a member if you want further assistance with you S10. https://forums.androidcentral.com/showthread.php?t=409154&p=3754645&viewfull=1#post3754645 Otherwise, you should return it for a refund if you are still able to do so. Upvote 0 Downvote
