What would cause zoom to open when i try to place a call using direct call from the edge panel?
rogerculture
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens zoom and says my account doesn't support the activity. I haven't made any changes to my settings. It was working fine yesterday!
I would go into app info for zoom and check to see if it is set to open for defaults and also check on the question about supported links. Set it to never.
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens zoom and says "your account does not support calling.
I haven't made any changes to my settings. When I uninstall zoom it works, when I install zoom again, I'm getting the same message, this just started happening, wasn't having this problem before!
Thanks
Welcome to Android Central! I merged your duplicate threads and made you the owner of your original guest post.
Forgot to use the updated thread title, though -- OP mentioned it's an S21 Ultra.
I have samsung galaxy note 9
I use the edge panel.
The panel name is "Direct Call Panel" by "Sally Soft"
It was using the phone dialer usually but now it opens Zoom.
Zoom is not marked as a default application for nothing.
Same issue in Note 10 plus, edge direct call open zoom
When I open Edge direct call and try to call anyone, its open zoom
Do you have zoom app installed?
jipeve
