Re: problem
Also try installing the GSam battery app and see what it shows. Or look at the Battery screens and see if Android OS or another app is running too much.
Also turn off Master Sync, and Google+ and uncheck sync settings in Accounts - Google - your account, and see if that helps in the short term.
Sent from my XT1039 using Tapatalk
