A
AC Question
Hello,
I'm using Android in Europe with English (USA) set up. But, here in Europe, the OS must be on metric system. The problem is: the only way (that I found) to change the whole system to metric is by changing the language to English (UK), but, the keyboard starts showing "£" instead of "$".
Do you guys know how to change to metric system without changing the language? The change must affect the whole OS, because if I change Google Now (for instance), It doesn't affect the Snapchat fahrenheit unit...
