Samsung Chromebook Plus Build Quality
Uncle Meat
Hi,
I purchased a Chromebook Plus about 3 weeks ago and I love it, the ArtCanvas program is just awesome. I noticed after about 2 weeks that when I picked it up there was a clicking noise. After some investigating it appeared that one of the screws wasn't mounted correctly and that the case was loose, making the sound as the case clicked shut. Anyway I ordered a replacement and the replacement is even worse, a different screw, the one on the bottom near the front of the keyboard isn't even touching the part of the case that it is supposed to secure. I just ordered another replacement. I really want to keep this Chromebook, but I don't want a janky device. Any suggestions?
smokedog87
