I am using samsung j3 pro and i am facing problem that my device in txt msges showing+92number and not showing contact name how to fix that problem .kindly help to get rid off that as I did alot for that
Welcome to Android Central! What do you mean that it's showing you +92 number?
For the contact name issue, try going to the App Manager, select the Messaging app, then Permissions, and make sure it has permission to access your contacts.
