A
AC Question
Hi,
my note 4 was automaticly updatet last week (official update, android 6.01, some security updates, baterry drain optimization, etc) since then it keeps loosing mobile data connection. When I use, or try using internet the connection is going on for few seconds, off for few seconds, on for few seconds , off for few seconds,...
I had never experienced those problems before.
It's happening only while roaming, in my home network everithing workss fine.
