8/13/17Gmail won't print using S6phone to HP printer
  • Start date Start date
A
AC Question
As of 8/13/17 I have been unable to print any Gmail from my S6 phone using HP plugin to my HP printer. The print preview shows up and I press print button, the print Icon show displays as if printing/ notification on the phone says "print spooler is printing gmail" , but it never prints the document and continues in continuous Print loop until I manually cancel the Print Job from phone. The printer screen then displays notification that the file is corrupt, regardless of the Gmail. I can print photoes from Gallary and PDFs. Is anyone else having same problem or have a fix? Print service has some problem recognizing / connecting to Gmail (only) to print. The day before and prior I was printing Gmails like crazy.
That's another reason I stopped using Gmail. Most other email apps allow you to choose the print method, and I've found Cloud Print to be about the most reliable, regardless of the printer.
Cece_25
